Frank in Thailand
making mistakes so you don't have to...
I was thinking about the future.
Now I have 456Ah new Lifepo4.
In 3 to 5 years they have 80% capacity left, if I'm lucky.
Could be less.
While 80% is still enough for our usage, it will decrease to a point where it is not.
For lead acid, you can not mix old and new.
The old ones have absurd bad effectiveness and hardly hold a charge.
Most of all... They never are full.
You keep putting energy to it and it just gets lost (heat)
When you add new battery to that parallel string, the old will discharge the new one in not nice speed.
For Lifepo4, things are different (are they?)
The effectiveness is already at start a lot higher then Lead acid.
(+95 Vs -80%)
If my understanding is correct, the total capacity of older lifepo4 reduce, but that's it.
It still holds this reduced capacity like new ones (not leaking like lead acid who is empty after a week)
Also, the charging efficiency stay the same.
The 456 Ah battery just reduced capacity to 250Ah.
And is like 250Ah cell
It probably will decade faster then new cells, but that's OK.
In a parallel string of 3 x 152= 456Ah, who have reduced capacity to "only 250Ah" could you add 300Ah cells?
Making together 550Ah.
And yes, reduce faster the 250Ah part.
The 300Ah cells are not affected by the reducing capacity of its neighbour cell in the parallel set.
This is theoretically.
And only holds up if the charging efficiency and possibility to hold the charge stays unaffected.
If it is like lead acid, the new 300Ah cell will just try to charge the "now together" 250Ah set.
With doing so, it will discharge it self, and the old set will just lose that energy into heat.
To my understanding, the parallel sets in a string of series don't have to be identical.
Better, yes, for sure.
It can have a few 280Ah cells and a few sets made of 2*120Ah and one 40Ah., Together still 280Ah.
Naturally, there is difference in resistance for 1 cell of 280 and 3 cells combined.
An active balancer could compensate this without any real problems.
Please : shoot!! (Be kind and constructive!!)
I'm thinking about the future.
Could I just add cells and get away with it, or will this be big problem?
(I do have active balancer)
It doesn't have to be in 5 years, maybe in 2 or 3 years we need more energy.
Good to know if I just can add 16 cells to my 3*16 152Ah cells setup.
Those new cells can be anything lifepo4 that I would like to have more.
In 3 years.. who knows what the prices are.....
500ah for 50 USD??
Could be less.
(+95 Vs -80%)
500ah for 50 USD??
