rminkler
Hello!
I currently have 32 calb ca180fi cells in a 2p16s configuration. I use a Batrium watchmon 4 and each cell has a blockmon. I set the bank up about 3 years ago. My charge controller is set to charge to 3.45 volts. The batrium bms balances starting at 3.4 volts. The bms turns my inverters off at 3.18 volts.
I have a 4kw solar array, 2x outback vfx3648 inverters and a flexmax 60 charge controller. I plan on setting up another 10-14kw of solar later this year.
Last week I ordered an additional 64 calb ca180fi cells. I'd like to set them up with the old cells in a 6p16s configuration. When they arrive, I plan to charge them individually with a lifepo4 charger at 20 amps to 3.65 volts, then use the same charger to top off my current 32 cells, then assemble the new 96 cell bank.
As I understand it, cell level monitoring in a parallel configuration does not actually work very well (at all?), so it seems like my best option is to remove 16 of my blockmons and set up the bms with only 16, one for each group of cells in the series.
I'm wondering about the ramifications of mixing old cells with new cells. Should I include 2 of the old cells in each 6p group? What's the likelyhood that this setup will be problematic? Would I be better off buying 32 more new cells and re-purposing the old cells?
Thank you for your perspectives!
