Mixing different battery sizes? Same voltage.
WillAK
I have 5x lead acid 12v 245ah batteries, each of which have different capacities. Some are older than others, and some have been used more.
I did a discharge test on each individually and they are all different:
B1: 1285wh
B2: 1214wh
B3: 715wh
B4: 645wh
B5: 645wh
My question is, can I put 4 of these cells together in series/parallel to 24v and get 3859wh? Or will the lowest battery cause problems once its full?
I don't want to damage the batteries further, but as soon as my LifePO4 batteries arrive they will be useless anyway, I just need something to last me until they arrive.
You will get the sum total of 4x the lowest batteries capacity, so 4x 645 = 2380
(At best!)
B1: 1285wh
B2: 1214wh
Youd probably get better results with just these two batteries in 2s for 24v , 2499wh capacity
Yeah that's what I thought.
Ive currently got the 2x larger batteries together. But the others are just being wasted.
If that's the case then these two would be 2x lowest @ 1214 = 2428wh total?
3p for 12v ? Separate little system?
Yeah that's what ive done. I have 3 separate systems. But that means 3x inverters and I have to run extensions and battery chargers to keep them topped up. It's a pain. So I wanted to just stick them all together to make things easier.
?. I know that feeling
