I have a small LiFePO4 battery bank made up of 100 Ah 12V batteries with 1C discharge rate and 100 Amp BMS. I was offered some additional batteries that are the same except some have 100 Amp BMS and others have 200 Amp BMS. Does the difference in the rating effect how the batteries charge and discharge in a real world application? I realize that the BMS rated at 200 amp can maintain a higher continuous discharge but I am assuming that the discharge rate will be determined by the lowest denominator. IN this case then the batteries would all discharge at a max rate of 100 amps. If it makes a difference, these are all connected in series to 3Kw 12vdc to 120 vac inverter/converter with a max charge rate of 100 Amps.
