Seplos 10e BMS will show on my solis app that is max charge rate is 50 amp and discharge is 90amps. But will only charge at .5kw for several hours that seems to be 10amps roughly. That is when I have it set to user defined. If I set the inverter to pylon lv profile I am getting the 50amps 2.5kw charge but the problem with that is my discharge is only 50 amps so not sure what settings I have wrong.
under user define max charge and discharge are both set at 100 amps.
