Galway Bay
My setup is two seplos mason vertical batteries with 16 envision 305Ah batteries in each one, the BMS's are E10's. My inverter is a Solis S5-EH1P6K-L running firmware 470045.
I've a basic question on the inverter settings, in the photo below Seplos told me to change battery capacity from 208Ah to 305Ah but if I have two batteries in parallel should it be 610Ah ? The reason I ask is that my shelly is showing figures double that of the Solis so something is not right.
Seplos also gave me the settings below for user defined battery, the i max discharge & charge of 60A seems a bit low, should it be 100A ?
Thank you
Thank you
