In February I purchased one of those 24v 200ah BYD lifepo4 batteries and it's been working great. I get about 150ah out of it.
I recently found a deal on Craigslist for some sonata 5300 batteries at $1 each, which are basically just two 18650's in parallel. I ended up buying 420 of them, and creating a 7s60p pack.
I've tried a couple different configurations.
1. I left the charge controller set for lifepo4. This works but the lipo batteries only get charged up to 27.2v 3.9v per cell and that's not high enough for my liking.
2. I set the charge controllers to 29.4, which charged the lipo batteries up nice and high, but too high for the lifepo4 battery. I had to disconnect the lifepo4 battery once the voltages got too high, or the BMS's over voltage protection would trip. This seems to work OK but I don't like pushing the old BYD batteries too hard.
3. This is the current way I'm doing it, and it seems to be the best, but I'd like some input. I have the Charge Controllers set for lifepo4, but once the voltage starts to get high enough, I use relay's to disconnect the lipo bank, and charge it using this DC-to-DC charger https://www.amazon.com/gp/product/B07N6BJWXH This way the voltage stays under the limit for the lifepo4 bank, and I can charge the lipo bank up to around 4.2. Once the sun goes down, the relay's reconnect the lipo bank, and it basicly keeps the lifepo4 bank floating until the voltage starts to fall withing it's usable range, then they discharge together.
I haven't found much on the internet about mixing lipo and lifepo4, and figured if anyone has done it, it would be here.
ps. both banks are protected by separate BMS's just in case.
