ADDvanced
- Sep 6, 2022
- 133
I get that it technically 'underperforms', but all 3 of those mixed diagrams above are at least 145 more watts of solar than I have now. I've been reading a lot about mixing panels, but nowhere did I read about smaller panels discharging into the larger one, have a link?
Parallel would provide about 360W, but there's a risk that the SanTan would simply discharge into the renogy, and you get nothing.
Mix would provide about 360W, but there's a risk that the renogy would simply discharge into the santan, and you get nothing.
I revised:
As you can see, it's not about smaller. It's about voltage.
Current flows from high voltage to low voltage. The higher voltage string of a parallel can see the lower voltage string as a short circuit.
If you're close where The Voc of the lower string is still higher than the Vmp of the higher string, less chance. You are proposing strings that are 33-50% different where ~10% is typically the max.
I understand what you're saying, I guess I just don't understand why this is. I've been googling and reading mainly posts on this forum about parallel strings of different voltages, but nobody ever really says why.
For almost every other solar theory/basic thing I've had to learn, there are a lot of articles that go into detail on the subject, but for this one, it seems like it's mostly discussions in forums.
If anybody has any links, I'm willing to read them.
You accept that a charger works by providing a voltage slightly higher than battery voltage so current flows, yes?
i.e., battery at 12.0V, charger at 12.05V, current will flow into the battery. You have two sources, yet one "discharges" into the other.
Why do you not accept a slightly higher voltage source not flowing current through a slightly lower one?
No, it makes sense. I just want to read more about it, the 5-10% voltage thing is mentioned a lot on forums, but I'm not finding any nice articles that go into more detail. Like, a lot of the articles about mixed panels don't even mention this, which I find surprising.
