I’m building a mobile power box with a 200ah LifePo4, Victron Phoenix 1200 Inverter, and a Renogy 60am MPPT. The goal is to charge either via solar or a/c. My question is related to proper grounding. With this being mobile I’m assuming I leave the inverter wired as a floating Neutral as it comes from the factory. I have some unistrut framing inside the box to mount things.
I’m wondering if the earth/chassis ground of the Phoenix inverter should go to my internal metal frame work along with the battery negative? Or with the floating neutral do I not want anything tied together? Just confusing information out there on this subject. Or do I not do any ground at all since nothing to ground to externally.
