It appears that the Tracer5415AN can monitor/track the power consumption of the load on the batteries.
My questions:
The (2) panels are wired in series and are wired directly into the charger, although I am going to install a 10A breaker. The Li batteries are connected in series and are wired directly into the charger, although I am going to install a (5?A) fuse. The 24V device is directly connected to the Li batteries, although I am going to install a 5A breaker.
What's working:
My questions:
- Can the Tracer5415AN monitor the power consumption of the load on the batteries?
- If so, how can I do so with my system?
- What are the load monitoring parameters on the controller screen referencing?
- Tracer5415AN
- (2) 20V 5A / 100W solar panels in series for 40V 5A / 200W combined
- (2) 12V 100Ah Li batteries in series for 24V 100Ah combined
- 24V device drawing up to 3A
What's working:
- Monitoring solar power generation
- Monitoring battery power capacity
- Using "(Load) dry contact interface" (characteristic 12 on page 3 of the MPPT Solar Charge Controller User Manual, referred to as the manual from now on), based on the disconnect and reconnect voltage settings, the output signal is intended to connect to the coil terminals of a relay (or the start stop terminals of an inverter, as described in the manual on page 4).
- In order to use the "(Load) dry contact interface" an RBVS (Remote Battery Voltage Sensor) must be connected to characteristic 11, the "RBVS interface", which is a second connection to the terminals of the batteries in series solely for measurement purposes, as depicted by the diagram of the "Single controller" on page 11 of the aforementioned manual.
- The "Dry contact" for the Tracer5415AN has a max output of 0.5A/60VDC per the specifications table on page 22 in the manual, which correlates with the small terminals on the connector for the "(Load) dry contact interface", effectively eliminating the possibility to connect the 24V device / the load directly to the "(Load) dry contact interface". *This assumes the "Dry contact" entry on the specification table on page 22 refers to "(Load) dry contact interface" depicted on page 3.
