chrisski
Solar Boondocker
- Aug 14, 2020
- 5,344
Do you really see earlier production by putting panels in series to exceed the charging threshold? I don't, but I'd like to hear your experiences.
I thought I was getting a bit of watts doing this, but I’m not. For example panels set up 3S for a potential 66 volts to squeeze more watts early in the morning while charging a 24 volt battery. I estimate by going with 3S instead of the bare minimum 2S to get the early production I produce less than 10 watt hours extra.
My Array:
3S3P
Panels 100 watts
VOC: 22
VMP: 19
I did this on December 1st in the Northern Hemisphere so about three weeks prior to the shortest day of the year.
This is my 3S3P setup at 7:14 with 35 volts making 2 watts. (11.6 Volts Per Panel; 22.6 volts per 2 panels Below Charge threshold for a 24 volt system; 1P3S am only producing .7 watts for a 6 kWh daily requirement)
This is my 3S3P setup at 7:36 with 44 volts making 24 watts. (14.6 Volts Per Panel; 29.2 volts per 2 panels; Marginally at charge threshold 2S for a 24 volt system, but only 8 watts with 1P3s so 16 watts if 1P2S; 3S3P I am only producing 24 watts for a 6 kWh daily requirement)
This is my 3S3P setup at 8:07 with 58 volts making 461 watts. (19.3 Volts Per Panel; 38.6 volts per 2 panels; Above charge threshold 2S for a 24 volt system, 461 watts with 3s3P so 102.4 watts if 1P2S; 3S3P finally producing 461 watts for a 6 kWh daily requirement)
Wish I had graphing software for this. Also, the 30 amp SCC is slightly overpaneled but will produce 840 watts when maxed out and on a sunny day will reach this by 10 am.
My Array:
3S3P
Panels 100 watts
VOC: 22
VMP: 19
Time | Total Watts 3S3P | Producing if 2S | |
7:14 | 2 | No | |
7:36 | 24 | Marginal | |
8:07 | 461 | Yes |
