July 7, 2020: My Ongoing
LV2424 Configuration & Testing and Adventure:
Wondering If this is normal for the LV2424 (I now have 3 configured for 240vac Split Phase),
... or If there might be a Firmware Update Fix for this challenge/ or some way to configure better:
I would like to leave my Grid IN ON, as a backup for overload situations, while working to understanding all my options properly. In my Testing of different settings: I notice with GRID IN; w and Solar OFF, (configured for 240vac split phase); With number one setting of SUB chosen (Utilities supply beyond Solar Input) = My Battery Charger gets actualized/ vs choosing #1's "SbU" (Battery supply beyond Solar Input) = my Battery Charger stays OFF (and might go on later via setting #20 (for Stop on Battery discharge when Grid In).
I like that Sbu option with Grid IN, and using the batteries and solar to power loads, ... and that
works Until I flip breaker to include PV IN, ...
Then with PV In to one of three All In Ones,
I get grid plus solar supplying all loads with no battery draw, and instead have the grid float charging my batteries. Playing with Setting 10 for Charger Source Priority does not made a difference, and I current have that setting on "CSO" for Solar First Priority.
I read one other LV2424 thread (
https://diysolarforum.com/threads/mpp-solar-lv2424-kicks-butt.5852/ ... with at least one other LV2424 owner testing and configuring these same options, and then leaving Grid Input OFF for his solution (not one I desire), or using battery timer for one hour and low charge rate (something I might try next).
I have an
extra challenge to understand from configuring 240vac split phase (specifically: a setting 30 defined in parallel or 3 phase section of manual (that include directions for 2 phase)/ ... have selection options for ONE or ALL that might help me/ but that # 30 conflicts the "LV2424's "Start charge timer for AC charger" (on same #30 setup); The Split Phase (ONE or ALL) does Not Show up in my current viewing attempts (I have faint memory of seeing it on original 240 split phase config/ but not sure).
I have some ongoing research, and think I may soon put my Questions to MPP Tech Support.
Attached is picture of my Solar Wall. Have 2 inexpensive circuit breaker boxes: 1) 240vac Grid power INPUT to my house/kitchen subpanel (ON or OFF), with option of All In Ones INPUT to subpanel (one breaker per LV2424). 2) Then other breaker box for Grid Input to each LV2424. Plus have my Chargery BMS8T relay triggers wired to turn OFF all 3 of my LV2424s Inverters (further battery draw down) for (if) discharge side fault; Plus: via 2 SSR dc-ac underneath my Grid In Box to each All In Ones, I can cut all AC chargers off via a BMS charge trigger. I also configuring to cut off all PV Input via same BMS charge side fault trigger. ... Pre- full on Solar Input; Currently just running 400 watts of Solar In from old array on my roof. Welding up and mount my 1st solar rack on roof for 1st 2000 Watts worth of PV next week, to be followed by 2nd 2000 watt set of PV.
Learning More from Hands On :+) Bill
:+) Bill
