Is it charging at the time of voltage variance? Not untypical to have it higher at the AIO since it is pushing charge to the battery and you may have line loss. I will say that voltage readings from many of the inexpensive AIO's is not perfectly accurate. If over time your testing with a independent reliable voltmeter shows a consistent difference when battery resting you might change your charge voltage values. As far as I know there is no way to calibrate the voltage readings at the AIO.
