bugsysiegel
- Sep 28, 2020
- 14
Hi guys,
I have searched through the forums, but so far have not found answers to my questions - problems, I'm experiencing with my new MPP PIP MAX 8048.
Let me keep this short, hope someone can help me out:
1. the mpp is not charging a battery from the ac generator I have. I have been through all the settings, even followed Will's advice on youtube with a different MPP unit, the only thing I have not done is bridged L1/L2, but I have 230V system, the genny is 230/50hz, so this should not be needed. The MPP just won't charge the battery.
2. the second issue is communication with the battery, using Pylontech protocol. I have EEL battery 48V box (https://eelbattery.myshopify.com/pr...type-without-cellssuitable-230-280-302ah-cell) with 16x 3.2V 280AH batteries, working fine, protocol set to PYlontech, I use standard networking cable between mpp and battery. The mpp after a few min gives me error 61.
3. if anyone has a similar setup, can you share your setting for optimal setup?
4. I have no luck setting up watchpower android app, does anyone have a trick up in their sleeve? Simply, when I connect the wifi mpp to my wifi network, it always fails, I have tried to connect ti to a mobile hotspot of my phone, same issue, so can't use it at all... And trust me, I know IT, but this time I have failed misserably.
I would greatly appreciate your help. I will owe you big time.
Thank you.
Oliver
Thank you.
Oliver
