gouthro2002
Hello,
I was thinking of building a solar energy system as a backup for my house and also for camping. In reading Will's site a little more carefully, I noticed that he recomends an all in one system. And I am wondering whether it would work for me? As you see, I am on the beginners corner, so a lot of what is said goes over my head and I would appreciate it if someone could clarify me on whether this system will do what I want.
One thing that Will says makes me a bit concerned. I want to run a 12 volt fridge/freezer when camping and one of the cons that Will mentions makes we wonder about this possibility:
Cons: High idle consumption. If you wish to have your inverter on 24/7, you may want to invest in a victron or xantrex (but they will cost 3x-5x as much money). Because the idle consumption is high on these all-in-ones, you will need at least 400 watts of solar panels attached to your system to offset the loss. If you do not plan to have your inverter on 24/7, this is not a problem. As i understand it to run a fridge would require 24/7 an hence this may not work.
That makes me think that a fridge,which you would normally want to run all the time, might not work on this. I have to admit, though, that I am not really sure what he is saying here. I would appreciate any help on this question thanks Joe
