Currently have a 24v LifePO4 battery being charged/used by a MPPT charger/inverter combo (MPP solar HV-LV2424 (green)). I currently have it set to charge to 28.5v. I was thinking for adding anther small array on a little PWM charger (says it auto selects 12v/24v) to the same battery. (Main reasoning of using a PWM rather than adding in with the LV2424 is a difference in voltage/PV panel specs) Any foreseen issues here?
