MQTT to SMA Modbus TCP Node-red flow
kommando
UK
This flow is specific for a Solax X1 Boost to emulate an SMA Modbus TCP inverter. This allows me to use my Solar-log data logger with an Inverter it does not support.
It should with adaption also be used with any Inverter MQTT feed for adding a non SMA Modbus TCP inverter to an SMA data logger that normally sees SMA Modbus TCP inverters, if someone could test this it would help to confirm.
https://flows.nodered.org/flow/7db69e53 ... 4092c4308a
Maybe search the forum using key words. .. this is out of my info. zone unfortunately...?
