HomesteadDad
- Oct 1, 2021
- 10
I am looking for expert input on my situation. I am looking at building my first solar system and am trying to do it with an eye to the future.
My current needs are as follows:
I would like the system to be partially modular as I have two needs for it.
I have a school bus I am converting into a camper where the system will live the minority of it's life. I also have a pole barn where the power comes into my property and then goes from that panel to my house. The system will live most of it's life in the pole barn. I plan to have a permanent array on my bus and a separate array next to my pole barn. I want to buy one all in one inverter and one battery that can be moved from the barn to the bus when we travel. When we aren't traveling I plan to have the solar system run a refrigerator and two freezers while the sun is good, and have the grid power them when it isn't.
I have a line on used Trina 235 watt solar panels and plan on putting 4-6 on the bus and 6-8 in an array next to the barn to start. If I go with 24 volt, I am maxed out at 2000 watts input whereas if I go with 48 volt I believe I can look at 4000 watts.
I'm also thinking that if I choose to airbnb the bus regularly in the future I could keep the 48 volt all in one in the barn and buy a separate 24 volt for the bus to keep there.
I'm just thinking for future expandability I should go with 48 volt. Am I wrong? Thanks.
