shadowmaker
I think I can't parallel because of different battery chemistries?if you parallel them together , your sense problem will also be solved, as the master comms the measurements to the slave(s).
i found the CT's to be rather inaccurate, no matter what direction i point the arrow.
could be due to the amount of cable ( magnetics fields) and space i had in my incomming powerpannel
did away with the ct's completely and put in a eastron sdm630 modbus v2.
looks better, works extremely precise and used modbus, with runs fine over longer distances and utilizes cat6 cable
They should change my meter for a bidirectional one. Maybe there is a CT output? Maybe far-fetched, but if there is, it should be accurate.
Are your CT readings positive when you buy from grid and negative when you sell?
