shadowmaker
I am more concerned about high winds, but you can be right. Time will tell. I have done some precautions for ground heave force by hammering (not digging) those poles all the way to 2m deep + some insulation around the poles. Ground frost can be like 1m here, but not on the wheatfield like this with snow on it. It's more likely to have max 30cm of frost, but I guess even that can cause some changes on the poles. I have geothermal heating in my house and it is taking heat from 1m deep buried pipelines (3x500m) underneath another field nearby and even that never gets below freezing. Usually there is still +2-+4C on the ground when heating season is over.I think your failure mode will be the poles, the ground heave force will rip the frames apart like paper ( think ice expansion sinks ships )
thumbs up for all the efforts, and would be very happy to be wrong about failures!
Also I'm using homemade SS fasteners to leave room for pole movement. There's also 4mm mudflap rubber between fastener and frame to reduce movement and sound.
