ShanePowerHouse
- Dec 14, 2022
- 29
One of the things I said was if his RV Fridge senses AC power from the Inverter, then I might auto switch to AC instead of Propane. Most RV Fridge have a way to force them to stay on Propane.Exactly my sentiments.
First off, an absorption fridge isn't meant to be run off a battery. It consumes way too much power. The fridge ac usage is meant for shore power. An absorption fridge operates sparingly off propane. That should be the primary energy source.
Per spec, the Dometic DM2862 consumes 440W ac power. No way should consumption be much higher than that. If it is, then something else is going on. Perhaps a measurement error or something like the converter being active and is causing an exorbitant load. But it's not the fridge. If the fridge was at room temperature prior to making the measurements then it will be at 100% duty cycle for a number of hours. Once it starts cycling power at perhaps 70% duty cycle, in 24 hours it should consume: 440W * 70% * 24 = 7.4 kWh. This data should have been known before starting the project!
How much power does the new fridge consume? Per spec, it has an energy consumption of 339. Not sure what that means. This article says a fridge like the new one consumes about 150 Ah in 24 hours. That's 1.8 kWh in 24 hours, or about 4 times more efficient on ac. It's still a lot of energy where long periods of clouds in the winter could run down the battery. That wouldn't be a problem with a propane fridge.
I did check my LG Fridge in my Second house it's Model LSXS263365 /03 This house is off grid on solar and using a KWH meter that Fridge uses 1.2 KWH per 24 hour period and it's a full size fridge. It has a Liner Compressor. As a note if this LG Fridge losses power or power it dropping on and off a few times over the 24 hours it will keep going into defrost mode and use much more power.
