I have a 2 felicity 8.7kw lifepo4 batteries connected in parallel.
I also have 2 Growatt 5000 es connected in parallel to the batteries as well.
Each Growatt has 8 panels 550W.
I configured each Growatt to have a max charge current set to 60A.
All past week was rainy and no sun. Today is the first day that the storm is over is considered semi-sunny (with some clouds). Also the tempratre is low. Today sis 8 degrees Celsius.
Today ~ 10:25 am the battery bank SOC suddenly spiked from 44 to 63% in 5 minutes.
Battery voltage remained 53.5 when this spike happened.
Is this normal? Is my battery damaged? Anything I can do to make sure the batteries are still ok?
I attached an image of the SOC, battery voltage, and PV voltage.
Thank you!
Thank you!
