I'm absolutely no expert here but if only one battery shuts down it sounds like the battery is the problem. If both batteries were balanced properly this should not be happening but maybe someone else on this thread is better informed. As far as the Solar Assistant, while it does appear to be a great package i ended up not buying it. It is produced in South Africa and me being in the States made it a bit pricey to have the full system mailed. The download option is much cheaper (obviously) but then I'd have to buy the raspberry Pi, etc. So, instead i just used the Watch Power software that came with the inverter. Yes, it is quirky but you can export the graph data as an Excel friendly file. I have MS Office so i imported it into Excel and then was able to evaluate the data.
