Irishbrannan
Hi! I am new to this forum and absolutely love solar and wind generators. I want to build my own off grid small scale home system to help lower energy costs and have a backup power system capable of running a small window unit, dc low voltage lighting (e26 led) and a fridge/tv whathaveyou. I wanted to use 6 200 watt panels and a inverter along with two 200 amp renogy batteries. At first, I thought a pwm controller and 12 volt inverter to keep it simple, but now I don’t know if I should go mppt? I Also realize now a 24 volt inverter is more efficient. Is there any way to wire these 6 12 volt panels together to utilize a 24 volt inverter? I thought I could wire 3 together paralleled and then series the two strings to achieve a 24 volt load and then be able to use a 24 volt inverter correct? I also live in southwest Louisiana and face hurricane season every year and that’s why I listed only wanting to run those few things to survive on during power outages that last for weeks of not months on end. Any help or direction on wiring, charge controllers, or inverters are greatly appreciated and thanks for your time
