What kind of loads will you be connecting to the battery bank? What size of inverter?
Is this in an RV? If not - consider going 24v.
For bus bars - you need thick tin- plated copper bars - do NOT get brass ones.
Blue sea makes a good one. My favorite is a Victron PowerIn (you can add fuses lookup how on YouTube). The Power In has both the positive and negative in one device. It only handles 4 - but you can add on.
Fuses protect the wires - not the devices. So to know what size of fuses - we need to know what size of wires.
My assumptions:
#2 wire between batteries and bus bars - use 100a fuse.
After bus bar - use 4/0 wire & 400a fuse.
After your battery buss bar - you should have on the positive wire the fuse and a switch to turn the system off. On the negative cable you should have a shunt based battery monitor - like a Victron Smartshunt or BMV712. That way you can know how full/empty the batteries are.
Then you should go to a distribution bus bar - inverter, Solar charge controller(s), other loads, etc go on this bus bar - anytime you go to a smaller wire - say #6 to the solar charge controller- it needs fused.50a for #6 or a #14 for a light - #14 needs 15a fuse.
If you get a short in any wire - the fuse for that wire will pop at the wires rated capacity.
Did my novel make sense? Or did I screw up the way I typed something…
Good Luck
