SandboxWilderness
- Feb 16, 2021
- 4
I'm assembling a 24V battery pack using 16 280A cells. My pack is being used to power a big, 6,000W low frequency inverter (AIMS Power 24V 120hz UL-listed model). I'm trying to figure out the best (and safest) way to get the power to the inverter.
I was planning to use 24V 8S Daly BMSes on the two packs and then put them in parallel. I received one of the BMS' , and frankly, the wiring looks stupidly small (6 gauge, I think)... I really don't think they are going to cut it.
One option that came to mind was to make a single 2p8s pack with the Daly and just use it to control a Relay on the output side. Doesn't help me for input, but my charge controller has temp control, so I think I can live with that. If this seems like a good option, does anybody have a suggestion for a 500A 24V relay? (my inverter can run peak loads of up to 18,000W, but I can't see ever using more than 12,000W)
Another option is to abandon my Daly and go with a different BMS that can handle more power.
Would love some recommendations.
