SolarHead
50% of people are below average. (Its a statistic)
My questions are in regards to switches . I show my 2 questions above in the image and I will explain them below as well. Everything in my existing system is in the diagram above except the Transfer Switch (shown in purple). I do not have a transfer switch yet. I just have a wire running from the Sol-Ark over to the Critical Needs panel (which I wonder about if thats a thick enough wire, am considering upgrading the 6ga to a 4ga instead). This wire would of course come out when I install a transfer switch, but I would use the same 4ga wire when wiring up the transfer switch once I get one.
First Question (#1 in diagram) is shown above in regards to a Transfer Switch that I do not have yet but want one (I think its a good idea but argue with me please). Its in regards to wanting to buy a transfer switch, manual or automatic. I like the idea of a manual switch , but if we're not home , freezer goes out and food spoils so probably would lean more towards automatic. I dont know what to buy. I've looked at many transfer switches, not sure if Generac makes one or not. I think 100A minimum, maybe go with a 200A since my critical loads panel is a 200A panel (identical to my other two panel boxes) but I dont have 200A worth of breakers in there and don't plan to either. I think a 100A would work but not sure. Any advice on size/type/brand/model of ATS would be appreciated. I wondered about a Generac ATS (or any ATS for that matter) detecting the hertz that the generator or house puts out and getting confused and causing an issue. I want an ATS that is meant for this situation or configuration and really solid. Not concerned with price as much as I am with functionality and being sized right.
Second Question (#2 in diagram) is about the Safety Switch is already installed and working but not sure I wired it correctly in regards to the Neutral wire since I read something where some inverters want/require that, and some do not.
