well i will need to charge this batteries when i get them here because they will not going to be put in use right away ...I only have solar chargers, nothing from grid.
Thanks can you recommend a charger ?Series connected batteries will result in lower battery current at a given wattage meaning lower gauge wires that are cheaper. However, verify that the BMS you buy can handle the higher voltage. Parallel connected batteries will provide greater discharge current that may be required to run heavy loads. Higher voltage inverters (24V+) are more expensive but allow greater power output than 12V inverters. In general, high power inverters benefit from series connected batteries to keep the battery current low and reduce voltage drop losses in battery wires and interconnect. Low power inverters typically use low battery voltages to allow operation from cheap 12volt batteries.
nice but pricey hahaWIll's favorite chargers are here: https://www.mobile-solarpower.com/battery-chargers.html
Since I haven't used any of the ones he recommends I'll leave it to someone else to add their experience.
HelloHave you checked Craigslist for big cheap panels?
If you got 3 or 4 big panels,
900-1000W, you might be ok.
280Ah @ 25.6 V is a great battery (I have 2 of those on deck).
With 280Ah x 25.6V = 7168Wh
To just recharge, with nothing running, not even the fridge, you would need:
7168Wh / 5h = 1433W of panels to recharge in a day under perfect conditions an 100% efficiency. If you matched array to battery, for single day recharge, with loads, you’d be over 2000W of solar.
But if you calculate your usage (same as I did for fridge), you can get a realistic number.
HiWIll's favorite chargers are here: https://www.mobile-solarpower.com/battery-chargers.html
Also, realize that many of the All-In-One Inverter/Solar Charge controller units (like MPP and Growatt) will have a built in charger and can charge your batteries when the sun isn't charging albeit at a slow rate.
All-In-One's from Will
All-in-One 12/24/48V Packages
MPP and a few other manufacturers now sell a "complete off grid system in a box" that has: AC Inverter Solar Charge Controller AC Battery Charger Automatic Transfer Switch (if grid power is...www.mobile-solarpower.com
I am no expert but am looking into this as well. The term I have seen used most is “self consumption” where your inverter uses battery before grid.looks like a good option practical solution to use up the battery power i would get from the sun , it would switch from battery to grid not to use the fridge but maybe i can use a hairdryer and lights and low power devices ...What do you think about that Mr Sandals or any expert?
You should shoot for an even number of panels or you would need an inverter that accepts the 5x panel voltage as input (rare and very speedy). With 4 panels, 2S2P, 6 panels 3S2P or 2S3P are all reasonable array configurations.And i have room on my balcony for 4 panels maybe 5
this looks good ...https://sungoldpower.com/collections/24v-inverter-charger/products/3000w-peak-9000w-dc-24v-pure-sine-wave-inverter-with-charger?variant=39652727619721I am no expert but am looking into this as well. The term I have seen used most is “self consumption” where your inverter uses battery before grid.
There are quite a few, ranging from Growatt, to Victron Multiplus, Schneider Conext 4024 and more.
they look exactly the sameI believe the Sungoldpower and Aimes units are made by Sigineer.
what inverter are you using?I believe the Sungoldpower and Aimes units are made by Sigineer.
I am currently shopping and waiting. In California PG&E is about to make net metering very expensive for new solar installations (every new home requires it to, what a coincidence). So there is a mass scramble to get in the old NEM 2 rules/fees.what inverter are you using?
so the 8S2P would make 48 V and the 2P8S?I am currently shopping and waiting. In California PG&E is about to make net metering very expensive for new solar installations (every new home requires it to, what a coincidence). So there is a mass scramble to get in the old NEM 2 rules/fees.
When that shakes out, new solar will be dead except for new builds. Prices and availability should become more sane. Installers that sprung up, I suspect will start to go under.
I have my eyes on the Schneider Conext 4024. My main goal will be self consumption because I get about 25% back from selling back to the grid compared to what my average buy rate is. I have 16x 280Ah at the ready for a 8S2P or 2P8S battery bank.
I am expecting to connect my micro inverter array (3.2kW) to the self consumption side of the inverter. Still working out the details (if someone knows, please let me know!).
25.6Vso the 8S2P would make 48 V and the 2P8S?
so if i have 2 sets of 8 battery in series and if i connect them in parallel that would make a 560 Ah battery bank?25.6V
3.2V x 8 in series.
Yes, 8x 3.2V cells in series is 25.6V. (Retains cell Ah, 280?)so if i have 2 sets of 8 battery in series and if i connect them in parallel that would make a 560 Ah battery bank?
Here is this nice demonstration of the goldsun power inverter if you likeYes, 8x 3.2V cells in series is 25.6V. (Retains cell Ah, 280?)
2 batteries in parallel adds Ah of both batteries, so 280 + 280Ah.
Cell Configurations for 12V 24V and 48V LiFePo4 Batteries
Click on the orangebutton to get the document. This short deck shows 1P and 2P cell configurations for 12V, 24V & 48V LiFePO4 batteries. Note: This resource is a duplicate of the resource of the same name in the 'How-to PDFs or Ebooks'. This...diysolarforum.com
