yes it is draws 39W the victron draw 20WI regard these as high value (cheap but good) inverters with excellent surge capability and low efficiency (high idle drain AND low efficiency).
That unit likely burns 50W all the time, even when not powering loads. That's 1.2kWh/day - a notable chunk of the 560Ah capacity discussed. Unlikely to get more than 85% conversion efficiency on top of the high idle draw.
Something else to watch out for on these inverters when charging from AC...
They have ABSURDLY LONG absorption times, which is not good for LFP.
Their absorption TIME is based on 10X the time to charge to a voltage slightly below absorption. So if it takes you 30 minutes to get to absorption, it will spend 300 minutes (5 hours) at the absorption voltage.
Checked the manual:
If you have it set for Lithium, then the charge current is only 3.45V/cell with the same float. This is mostly okay, but you are signed up for a fairly long charge period.
so you saying it is not good for the battery if i use its charger function for my lifepo4 it would lower its life?
It can be turned off as well i did look
Any good inverter you can recommend in the 3000W ?
Thanks!!
this is for my 24 V 280Ah pack
Charger only turns on when battery reaches 21V
here is the manual for the Aims one but it is very similar
Also regarding it's power saver mode it would bring down the power consumption to 19W but people say this can hurt some electronic this pulsating current.... Also cannot be used with a fridge
From the manual: Power Saver Auto Setting : The inverter is factory defaulted to detect load for 250ms in every 30 seconds. This cycle can be customized to 3 seconds through the SW3 on the DIP switch.
Would the power saving mode be useful?
Thanks for any input!
