unmerus
Rad
Hi. New member here. I hope my system and other info i just logged when i registered is avalable to all to review. My problem is that my second battery has been repaired and reinstalled 3 weeks ago, there are sunny days that i check my system in the morning and everything looks ok and then i look again around 1PM and the batteries appear to be almost fully disharged and only recieving 120 watts. I wait a couple hours to see if they will recharge but nothing changes. So i go into settings and change the AC Charge setting to 0 amps and wait 3 minutes. Nothing changes so i change it back to ten amps and within 2 minutes the batteries start charging and drawing 600 amps. After 12 to 15 hours the batteries are fully charged. I have witnessed this about 3 times in 3 weeks. Probably BMS issues? Disconnect the battery that had a local third party non-solar technician repair the BMS? ( he took two damaged bms and robbed parts to repair other) Then monitor the system again? Or maybe i am way off?
