From a review I posted on Amazon over a year ago, yes the info from the manufacturer is poor;
There’s a new app for IPhone that allows the
"StartequalizationVol"feature. It has a new
title in the app store"GeeWe BMS" If you
have the old app on the phone you need to
delete and replace, don't update it with the
new one. To change the installed app to
English, open the app, click on the three
dots, then the gear, then the lower line of
chicken scratch, now the circle/English.
Restart the phone and it should now be in
English. To begin: open the app, tap the
three Lines, tap scan, tap on the results/
model on the top left. Now you are ready to
fill out the settings if you have it wired
correctly. When done, tap run and it will go
through testing before running/or till
parameters you set are in range to balance.
If you have the older version balancer, the StartequaliztionVol line simply won’t take.
