Tommytwotone
Are UL listed batteries required for a Net Metering install?
Net Metering is marginal as we would actually have to pay about 1cent more per KWH for the generation part to use net metering.
We use 4500 to 6200 kwh per month and have a larger than normal daytime load due to being home all day with home office and homeschool use.
As our kwh cost is about $.11 and we would have a $.01 cent increase if we go net metering which is one reason why Net Metering may not make sense. The other is due to our usage we will need a rather large battery bank and if that has to be UL listed, thus the main question, it starts to really erode the Net Metering logic.
The part of net metering that does make sense is we can get some credit for otherwise lost production AND as we have a 400 amp 2 panel (plus a 150amp barn feed off the meter) we can back to, when possible, feed the barn and or heavier loads such as strip heat if they happen to be active when we are feeding upstream.
Any thoughts are appreciated.
