This small load center is technically a sub panel to the 6000 XP....so its un bonded.....you can see I put a little ground bar on the side...
1- should that be touching the metal?
2- should I run a ground from this little bar to the house ground separate or can I splice it into the solar incoming ground that is in the 6000 XP?
but if I did that I would be effectively joining the bond again, no?
What do you think?
What do you think?
