I can’t see you getting an old replacement from that reply.OK, here is what HankzorBMS Store (SIC) who I bought from on Ali says about the change:
ME:
You switched products on me. If you will look at the photo in the top of this message, you see what the product looked like on your website when I ordered it - It had the long tabs that extended beyond the side of the circuit board. This one you sent me has short terminals and it will NOT fit in my battery box that I have designed for the long-terminal BMS like you your website photo showed last month This BMS will not work! The cables will short to the aluminum and a fire will result. I need to either get the long terminal 200A from you or I need to order it TODAY from someone else who is selling the exact item that is on their website.
All products have been revised and the production line has been adjusted. Thank you for your understanding,
while is not ideal, just grab some 20mm x 2mm copper and extend it to the old style dimensions to make it work
I guess that’s what I’ll be doing if I can’t get a spare for my 200amp units, as I also designed a box for it, I should have ordered a spare at the same time, lesson learnt on my end
