Hi all
I have a 4kw PV system on a single phase supply which is on FIT since 2012 and i understand that this cant be altered an any way.
I want to add more capacity in 2 different locations.
After a DNO application i have to have the supply upgraded 3 Phase.
One system is in the garage so will have to be single phase while the other new array can be either single or 3 phase.
My question is can the generated electricity be shared accross 3 single phases?
I am currently using Myenergi eddi to harness excess energy and propose the Zappi to charge the car so its important that any export energy is used up.
I have attached my draft single line diagram if it helps.
Thanks
Thanks
