Already one year with my first dump lifepo battery (Ampere Time 50Ah) and i was very happy that it was charging and discharging without problems with a victron 100/20 solar charger at 14.4 volts bulk when camping.
Until i entered the "magic" world of "smart" batteries and my happiness dissapeared and many questions appeared.
ok , here it goes the first one. A couple of days ago i got a Basen 230Ah smart with JBD bms (this is installed as factory bms). Settings have an overvoltage CELL protection of 3.65 which is totally legit. and PACK overvoltage is 14.6. Perfect !
BUT if one cell is out of balance and reaching the threshold, then BMS cuts in and disables charging, which is again perfect.
The result is as you can guess, is that battery charging never gets to a final voltage of 14.6 or even 14.4 but stays at f.e at 13.9. This otherwise perfectly fine behaviour continues on every charge and its not as my dump battery. How can i make it "behave" more properly? (reach 14.4V at full charge) without always cutting at lower voltage because of cell ovp?
