JitteryJoe
Hello all, new member here in greater Cincinnati. I recently became interested in solar and am in the beginning stages of researching / planning / deciding on whether a grid tie system would be a good idea. I feel like I have a decent enough understanding of wiring and the whole process except for the actual connection to the grid. I believe the easiest way is to connect through a breaker in the panel box but I am unsure of the best way to get the wiring from the outside down to the panel box.
My meter is conveniently on the south side of the house and then there is a large PVC conduit running down from it to the basement where my panel box is but that area of my basement is finished so its difficult to see exactly what's going on there and if it would be possible to run additional wire through that conduit or if I'd have to drill another hole through the foundation to run another wire through.
According to the power company (Duke) the smart meter they installed a few years ago is already capable of net metering. Is it possible that it already has a spot to tie in solar panels? (I heard they made meters like this I'm just not sure if it's common for the utility to put them in.) If so is there something specific I should look for?
Where do I go to find out if I need any permits to install a ground mount? I feel like I read that I don't need a building permit but may or may not need an electrical permit? From the utility side it seems like I just need to send them a line diagram of the system and proof that the inverter is UL1741 compliant but if anyone with personal experience could weigh in that would be much appreciated.
Thanks in Advance
Thanks in Advance
