Jimmy, I have the Powermax Lithium version converter that has the 3-position selector switch for: 3-stage, Li-Ion 2-stage & Fixed. I'm looking at relocating that switch (and associated led indicators) from the converter to an external location similar to your resistor/switch setup. That way I can easily switch between 2-stage and fixed when I need the fast charge current (Bulk) when Boondocking on generator. Interested in your thoughts on this configuration. Thanks.I've modified my converter with an external switch to select 2 different voltages. I also ran 12V from the converter to the switch panel to power an LED to show which mode is selected. The DPDT slide switch I used doesn't stick out beyond the little panel. So it can't be switched mistakenly.
Those voltages result in 3.3 V/cell and 3.55 V/cell
