Hey everyone,
I am starting a new build on a truck camper. I have already have 8-eve 304ah cells and 2 JK BMS'.
I think I am planning on going 12v with victron as space is limited and I want a inverter/charger and the multiplus 2 is only like 6 inches deep so it can fit under my oven or in a cabinet that is 8 inches wide.
Im having a little trouble planning the system. So many possibilites. So far I think im going with REC 420 watt solar panels that are 59v/9amp max each. If I run 4s on those then Im at like 240v/10amp and would need a 250/100 mppt but.... the max they output is 100amps and at 12v that would only be like 1400 watts to the battery bank. or... I can go with 2 strings and two charge controllers for 120v/10amp. My other options is to take the battery bank to 24v and that solves my mppt/panel issue, but this then brings a new issue of how to power the 12v systems in the camper. I know they make 24-12v converters but Im not super familiar with them.
Im thinking I should stick with 12v and just run two strings? but 24v is nice cause of the size of copper and keeping things cool pulling 3000 watts from the inverter.
would you run two strings of 840watts and two mppt's? or would you run the 250/100 mppt and over panel it? (id lose about 200/300 of max capacity. would you change your battery bank to 24v and figure out the converter to 12v?
thanks!
if youre in orange county california or have experience with this let me know!
thanks!
