While I will agree that they are dummy proof, and I've bought 3 of them in my life, I fear it would neither serve his needs NOR give him a good first experience with solar. For less money he can get something like a
Renogy 100w Kit or even better yet a
Weize 200w kit that will have actually useful panels, the wire, and a set of mounting brackets. They also both come with 30a controllers so adding in a 3rd panel in parallel is cheap and easy.
They say you never forget your first, and there are MUCH better options for his first solar experience than the HF kit. I almost gave up on solar completely because of those kits until I bought my camp. Back then there wasn't nearly as many options out there nor were there very many good resources to learn from so I figured there HAD to be a better way. Then the 100w panels started coming around for $150-200 each and I gave it another crack.
For other parts, especially for first timers, you can't really go wrong with the WallyWorld 120Ah DC29 batteries for about $100 out the door and readily available. I try to tell people that if you're going to risk destroying a battery, risk a CHEAP battery.
With pretty much every battery charger on earth using a switching power supply, he could even go with a cheaper Modified Sine inverter, although I would still HIGHLY recommend spending the little extra on a Pure Sine inverter. That's a worthwhile investment that will last you a good long while.
