NewbieSolar123
We love outdoor low voltage lighting. We have been using these unique individual solar power devices you get on Amazon but problem is most are junk and never charge the AA it uses to light up for more than 1 hour. So I decided to venture out. Did some research and bought a Renogy 50 watt 12 volt solar panel. Picked up the 10 amp Renogy controller with solar, battery and load controls. Picked up a 12 volt sealed AGM 9AH battery. And since these light don’t run on 12, they run on 2.6 volts, picked up a voltage regulator that takes the 12 volts and lets me down it to 2.5 volts. Now all is running. Lights are on. I can see they pull total about .20 amps which is very small and I run from dusk to dawn. So 10 hour roughly.
Problem I had, I didn’t realize the controller had an option to turn on the load when solar stops charging and turn off the load when it starts to charge. So I put a photocell switch on the load terminal before my voltage regulator that feeds the lights. And I left my controller on constant on. So during the day there was a small .2 amp draw from the photocell switch and then the added .2 amps at night. Second problem was controller was set to lithium charging and not sealer battery. Over night my battery which I thought is over sized went from 4 bass to 1 bar and it didn’t charge back up fully during the day. I have since removed the photocell and changed the controller to built in load controller based on charging and also changed the charging to sealed battery. Do you think this system is large enough to run that .2 amp draw for 10 hours and be able to charge back? Could it be that the battery didn’t charge due to wrong type?
Finally do you have any recommendations? I plan on adding a few more 2.7 volts lights. Maybe a total of 1 ah use. Should I change to a lithium of larger battery? I was hoping the 50 watt would be able to charge and maintain this small load.
Sorry for the long description but wanted to give the full background.
Thanks.
Thanks.
