Newbie in NC Minnesota
Thanks again for your help and quick reply!
PV voltage 48v
PV amperage 18a
2 panels in parallel
That breaker will be fine.
Might want to use ferrules on the wire if it is fine stranded.
I edited my last to ask about this Breaker. Maybe it’s too close to the operating voltage.
That is a single pole breaker.
You want a double pole breaker between the panels and the solar charge controller.
I can't see the datasheet hopefully its dc rated to the min 100VDC and 25 amps dc.
There aren’t any that I can discern. Is it these?
Sorry I don't know how to interpret that diagram.
Since their other breaker have line/load markings I think this breaker must be non-polarized.
Since their polarized breakers have the line side on the top...
Put the pv input into the top of the breaker(line).
Put the wires to the solar charge controller into the bottom(load).
Alright that would be like the diagram above with one side + and the other - ?
Can’t thank you enough for the assistance!
