ArtieKendall
I was reading this thread which pointed to this webpage which contained this statement:
"Finally, if you only have 2 batteries, then simply linking them together and taking the main feeds from diagonally opposite corners cannot be improved upon."
In other words, it claims you don't need busbars for optimal current sharing with two batteries. If true, it seems like it would actually be a disadvantage to use busbars in a two-battery system (at least for the battery connections), since they require more connections, and each connection introduces a bit more resistance. I'm setting up a two-battery system, and it would save me time and money if I didn't need the busbars.
I didn't see any comments on the two-battery statement in the thread linked above.
Can anyone confirm or deny that simple diagonal wiring is optimal for two batteries?
