Jim Burrow
- Jun 27, 2020
- 516
I have the PIP-2424LV-MSD by MPP all-in-one controller/inverter and for the last couple of months on my test bench, it has been running flawlessly while doing different testing on it and running a floor fan at 220 watts as a load.
Yesterday, I wanted to connect and test the system with a solar panel for the first time. But to make room in my shop, I needed to move my test bench over a little so I could lay the solar panel against the wall and get sunlight to shin on it.
So, to move things, I had to disconnect the battery(s). After moving the desk and batteries to their new location, I went home for the evening.
This afternoon, I went back to the shop (my shop is in my airport hanger without heat) and put a 50-ohm resistor (that I always use) across the PIP-2424LV-MSD control/inverter to eliminate that spark when connecting a battery. All went well and I connected the batteries to the controller and turned it on. – It came alive!
The inverter turned on, but there is no 120-volt ac output power out of the PIP-2424LV-MSD to the load. The MPP display shows there is 120 volts ac output to the load but there is no voltage at the output terminals of the controller. Measuring the ac voltage at the terminals, all I get is a pulsating ac reading and not 120 vac.
The temperature in the hanger is around 60 degrees F. and will within the controller operating range.
The question:
Has anyone experience this problem and if so, what did you find happened?
The second question, is there anyone in the USA on the west coast preferably in California that does repairs on these controller/inverters? I don’t want to send it back to China as it would cost more for shipping than to buy a new one.
If I had the schematic for this controller/inverter, I could troubleshoot it myself and probably do the repair.
Sure glad I didn't have the system installed on my house. I would be without house power right now.
The question:
