Hello everyone,
I got some parts from friends and I need some information and missing parts list for my design.
This system is Wind and Solar mixture.
My aim is to install an automatic emergency switch to the main 3 phase which should transfer the load a certain single phase. This single phase will have some certain lines connected to it like fridge, freezer, my network system and some lights. (Max 200W/h standby pull)
System preference is 24V but if you have a better idea, please feel free to let me know.
So here is what I already got;
1 x Ampere Time 12v 100ah LifePO4
4 x Jinko Solar Tiger Neo Solar Module
1 x Victron Energy Battery Protect BP 220
2 x 50A in-line Fuse
1 x 400w Wind Turbine (of course it is not windy all the time)
1 x Wind MPPT 12/24V
Not haves;
Cables, Bolts, Bus Bars, switches and whatnot….
Please fill in the blanks and share your ideas;
(Please define for which system you are filling the blanks. 12 or 24)
MPPT;
- If it needs to be cheap, than I would buy ……, but if I have enough money, I would rather buy ………
- The MPPT specs need to be minimum ………..
Solar Array;
I would connect this array in …… series and ….. parallel.
Batterie;
I know for 24v system, I need another batterie…
Cables;
- For Solar array I would use ……AWG.
- For batteries I would use ……. AWG.
I would really appreciate if you could help me out and even more, share your ideas about how you would integrate the wind tirbine in to this system.
Thanks so much in advance.
Not haves;
MPPT;
Solar Array;
Batterie;
Cables;
