AlaskanNoob
- Feb 20, 2021
- 906
I've got a short cable from each battery to a fuse holder, and then the cable continues from the fuse holder to the bus. I may need to extend my cable lengths though and instead of having long smaller gauge cable for that longer run, I'm wondering if I can keep the smaller gauge short wire to the fuse holder the same, and then have a thicker cable from the other side of the fuser holder to the bus. I figure by increasing the wire gauge on the other side of the fuse holder, I should be able to lengthen the run to the bus without increasing resistance too much.
Of course the negative cable doesn't have a fuse holder, so I may need to put some kind of bridge on the negative cable to do the same thing.
Any issues with this idea?
