I found a Xantrex 2.5 kw grid tie inverter (stxr2500 early 2000s) and a couple of 100w panels on the side of the road. I’ve recently built a 8’ x 12’ shed into which I am moving our walk in refrigerator. I can fit 5 panels on the south side of the roof and i will already have wiring, a breaker box and disconnect on the building so I’m considering using that old inverter and buying new panels to get near 2.5 kw. This would be a trial run before i put a 24 panel system on my garage.
Other than the lower efficiency of the older inverter is there any reason not to use it assuming it’s perfectly functional?
Is there a reason to get a reverse meter when putting in solar other than the obvious I won’t get credit if the solar ever produces a surplus?
I’d rather just put this in to get a feel for it without all the red tape unless there is a safety concern. I assume the grid tie inverter disconnects during a power outage? Thanks for any advice you can give.
Sven
Sven
