Hi all.
I just connected 16 new Eve Lf280k cells in 16s to a new 100 a Overkill Bms. All cells at 3.291 except for a couple at 3.292 volts.
Pack voltage 52.67. So everything seems ok.
Did not start charging yet.
But when I click the button to disable discharging "lock the discharge FETs in the off state" the pack voltage is 15.8 volts.
Is that the designed output? I thought it would be zero.
Thanks
Thanks
