So by what I've read on this forum, one can over panel the inverter and the MPP Solar inverters will only take what they can handle from the panels in terms of watts as long as one stays below the amps and volts. My plan is to string together 12 Rich Solar 200 watt into two series of 6 in parallel. I live in SE Kansas and in the winter we do get down in the single digits, I am using 7 *F as the morning low for figuring volts. Can someone with more experience with the LV2424 tell me if this is feasible or just hopium.
Also purchased an LV6548 I was going to upgrade to, but another member stated to upgrade the panels on the new 6548. So my plans have changed to leaving the 2424 in place powering the koi pond pumps, add more batteries, and also have it power the freezer and a small 110v AC in the inverter shed (11'x4.5') to keep it cool in the summer and heated in the winter (floor, walls, ceiling all well insulated). Now thinking will use the LV6548 to power the house leaving the Central AC and Oven (only 220v in the house) on the grid. The rest of the house put on the 6548, and power it with 20 or 24 Q cell 400watt panels. And batteries of course, ones that will play nice with the 6548 . Any thoughts, suggestions are welcome.
Thank you in advance.
