Greetings. I had an LV2424 I was using on my koipond with 4 12v Rich Solar batteries configured for 24v and 10 200watt Rich Solar panels hooked up 5panels in string, 2 strings. This setup worked fine for the LV2424, but the 2424 stopped switching over to utility, and it would just drain the batteries. This happened two days in a row and decided to reconfigure the batteries to make 48 volt and put the 6548 up. Made the swap, it detects the batteries and utility, but not the PV array and when I disconnect utility the unit shuts off after a minute.
The Rich Solar panels are 200watt each, and Isc is 10.2A. Imp is 9.8A. The manual for the 6548 states MPP 18A x2, so I am thinking the PV array exceeded the 18A, as when I figured it, PV array current is 19.6A. Also the unit was not providing any AC power out.
I did update the firmware also on this unit before this.
Thanks for any help you wish to provide.
zack
zack
